hypertech
Old 01-23-2007, 01:02 PM
chadnol10's Avatar
Default hypertech
if i put an intake manifold on my car or full system exhaust will the hypertech actually hinder my performance?
Old 01-23-2007, 01:46 PM
koolaid_kid's Avatar
Do you mean the tuning built into the Hypertech? If so, I would think not. The unit I had did virtually nothing for the performance of my car. They are really only good for changing things like shift points (for autos), gear ratios, tire sizes, and the like. To really muck up your tune you need something like HPTuners, LS1Edit, or similar.
Old 01-23-2007, 07:38 PM
5_02ls1's Avatar
all it does is turn up your timing and lean the car out.i use mine for gears only
Old 01-25-2007, 03:16 PM
pdanrichey's Avatar
I enjoyed my hypertech...it did make me some good power and no, it shouldn't hurt performance with your mods. Yes, it does have a tendency to run the car lean and make your knock retard sensors kick on in hot weather...that's why you should get an actual programmable tuning program like HP Tuners where you can add fuel and timing to get the best results.
