Street Racing & Kill Stories - 04 Z06 vs H/C ls1 SS
View Full Version : 04 Z06 vs H/C ls1 SS
1999ssls1
01-23-2007, 01:35 PM
The z06 is bone stock. The ss is mine with mods in sig. The guy thinks the z06 is a full blown drag car. Who do you think will win? By the way im gonna be on motor.
98Z28MASS
01-23-2007, 01:39 PM
Z06 off the spray, you if you spray...z06 is lighter than you and most will trap 116 mph+ bone stock so if he can drive he should have you off the spray by a few cars. On the spray you will walk him.
fastest94v6
01-23-2007, 01:40 PM
i would say you, but depending on weight also. But anything can happen (miss a gear etc) that can cost you the race.
1999ssls1
01-23-2007, 01:43 PM
both are 6 speed and stock weight. I think I can pull him, but i need some input
98Z28MASS
01-23-2007, 02:14 PM
What do you trap on motor? z06 is alround 3200 pounds so he will be a couple hundred pounds lighter than you unless you have a lightened car. Also, again most z06's will trap over 116 mph stock, so if its a roll race be ready to lose on motor if your not trapping at least 116 mph.
98Z28MASS
01-23-2007, 02:15 PM
Whoops didnt see you have ported heads, any dyno numbers or quarter miles times N/A?
1999ssls1
01-23-2007, 02:28 PM
untuned it went 12.35, but now its tuned and that is on motor
will82
01-23-2007, 02:40 PM
In the hands of a great driver, the c5 z06 in stock trim off the lot is capable of high 11 sec 1/4 mile times. On the freeway in high speed pulls the corvette enjoys a significant weight/aero advantage.
What kind of race?
How well can your opponent drive?
sidewayz28
01-23-2007, 02:42 PM
i got money on you! :devil: rooting for the underdog
will82
01-23-2007, 02:47 PM
I'm assuming from your sig that you have stock ls1 heads that have had a port job done. If it was a top notch job you have some advantage over his ls6 heads. Also, your cam is slightly larger than the ls6 cam. But your 3.73 gears give you no advantage, because the z06 m12 transmission mated with 3.42 gears is almost equivalent to the mn6 transmission with 3.90 gears.
So...
Heads - slight advantage to you
Cam - slight advantage to you
Transmission/gearing - slight advantage to him
Weight/aero - slight advantage to him
It's going to come down to how well he can drive.
12.35 untuned is equivalent to the average stock z06 1/4 mile time. You should be faster now, so if he's simply average or below average you should win.
1999ssls1
01-23-2007, 02:51 PM
We are racing on an 1/8th mile track. Im on drag radials and think he will be also
98Z28MASS
01-23-2007, 03:05 PM
Well if you went 12.35 untuned im sure you either hitting 12's flat or high 11's depending on how much the tune helped so id say with your gears and a sticky tire in the 1/8th I would give you the nod with comprable drivers. Let us know how it turns out!
1999ssls1
01-23-2007, 03:15 PM
Sure thing, thinks for the input.
Electric
01-23-2007, 03:17 PM
Should be a great race and pretty close but I honestly think youll pull him.
1999ssls1
01-23-2007, 03:34 PM
Im hoping so, if not i might have to cheat and push a button. J/K
sdm1234
01-23-2007, 05:42 PM
i think you'll win. vettes are the farthest thing from dragsters, so in the 1/8th, i think you'll take him. just whatever you do, POST THE RESULTS haha.
necrocannibal
01-23-2007, 06:39 PM
I think you will take him. Aftermarkets cams and ported heads and mated with better flowing exhaust (headers) give the engine more low end grunt and better power under the curve so unless you fuck up you fuck him up.
M6HuggerSS
01-23-2007, 06:59 PM
is there a reason you have h/c and NO headers?
you are leaving 20-30 hp on the table ......
M6HuggerSS
01-23-2007, 07:01 PM
and btw..... i raced my old car.....
400rwhp 99SS vs 340rwhp 02Z06....
and i had him the hole way..... 0-100.... the gap will grow as we went faster....
and the SS has 4:10's....
id say its a drivers race.
FU_I_AM_UltraZ
01-23-2007, 08:06 PM
from your mods in your sig... you have 373 gears, the z06 has 410s and is a 3150lbs car. a stock ls1 M6 car weighs just under 3400lbs. you have a 100 shot and his is BONE stock... you'll take him granted you shift w/o missing or sit and burn rubber.
necrocannibal
01-23-2007, 08:59 PM
Could the guy drive? That doesnt sound right at all. :suspiciou
1999ssls1
01-23-2007, 09:12 PM
I know I would get hom if I sprayed for sure, but im on motor.
tripps
01-23-2007, 09:28 PM
I'd say drivers race due to the weight advantage with the z06. you gotta get some LT's and then a retune! it would make your car sick. good luck
M6HuggerSS
01-23-2007, 09:51 PM
not really..... he didnt do that bad... it was my uncle.
both tires had traction issues..... if both had good drivers...
id say it would be neck and neck.
