General Maintenance & Repairs - car heats up when stopped
View Full Version : car heats up when stopped
Searching4Sierra
01-23-2007, 05:47 PM
i went out for a drive today and noticed that the temperature gauge would rise to the mark past 210 when i was stopped, but when i started to go the temp would go back to normal. do you think i need a new t-stat, waterpump, or radiator?
2001NBMZ28
01-23-2007, 07:18 PM
Remember your earlier post about the fans staying on after shut off, sounds like you're definitely overheating.
1987firechicken
01-23-2007, 07:32 PM
What he said your car is getting hotter than normal I have never cracked the 210 mark since i bought it but I'm in Indy so maybe because the weather out there. You want to check your colant level first and make sure you don't have ANY leaks in your system wich is kinda hard ( I had a leak that would slowly evap and was very tricky to find in my 87 TA) If no luck there then check the T-stat and if you really want you could replace it will a cooler one but dont go crazy you want cool air intake not a cold engine. Don't touch the radiator unless there is a leak in it that is NOT the issue.
staringback05
01-23-2007, 07:38 PM
check your radiator...several things could be wrong...from the fans to a peice of trash just blocking the front of it...
Searching4Sierra
01-23-2007, 07:40 PM
so i should start with changing the coolant and replacing the t-stat with a stock replacement. there are no leaks that hit the ground, but i will look for a small one
staringback05
01-23-2007, 07:45 PM
wouldnt hurt....get it flushed if your going to change it...crap tends to build up inside..and look into the mixture coolant, its a good thing
Searching4Sierra
01-23-2007, 07:55 PM
do i need a special tool to flush the radiator, i thought i just needed to empty it.
1987firechicken
01-23-2007, 08:02 PM
How many miles are on this car?? We know his fans at least turn on from his other post about them commin on when the car is off. I'd check the smaller stuff a t-stat is only like 80$ at the most a radiator is much more then that and a bigger pain in the ass to install. Check it for crap in the front like STARINGBACK05 said and have it flushed and a shop should be able to check how it looks. Also when I bought my car with less then 50,000 Miles on it, the water pump had been replaced. Take it a step at a time and be logical it isn't too bad on your engine as long as your not going too much past 210 and it comes back down quick.
thecorrectformula
01-23-2007, 08:08 PM
No special tools are needed.
TO PRESSURE FLUSH THE RADIATOR
If the temp is above freezing, use a garden hose.
Hold the hose tightly on the tank opening with your petcock (valve under the radiator) open for about 5 to 10 seconds at a time so you can feel some pressure but not enough to blow tubes.
Repeat this two to three times and let the radiator completely drain.
Make sure to shut the valve completely before refilling with a 50/50 mix.
If you do need to replace the T-Stat make sure its a stock replacement because if your engine runs to cool, you'll get carbon build up in the engine
Hope this solves your problem.
2001NBMZ28
01-23-2007, 08:09 PM
Overheating can be lots of things, coolant level, blocked radiator, water pump, tstat sticking, leak, radiator cap not holding pressure, etc. Do the easiest/cheapest things first.
SMKDFRD
01-23-2007, 08:17 PM
Remember though, when and if you decide to flush your radiator and any time in between only used specifed coolant and do not mix different types of coolants together. My 94 LT1 had the same problem and when I tore the car apart the cylinders had corrosion to them and I asked a expert and he said that because of the different chemicals in different coolants, they ate away at the block, causing a slushy type fluid flowing through the engine which wouldn't cool the car down very well.
SMKDFRD
01-23-2007, 08:19 PM
Yea, you should start off by doing the easiest thing first and then move on up. I can be simple as a bad hosing. Don't break you wallet to find out that it was a five dollar fix. Good luck.
Searching4Sierra
01-23-2007, 08:58 PM
car has 65k miles, i will try a flush along with a t-stat. and i will check to see if anything is stuck between the a/c condenser and radiator
thecorrectformula
01-23-2007, 09:04 PM
sounds like a good idea. Oh and that T-Stat will only cost around 25 bucks from a supplier like slp
koolaid_kid
01-23-2007, 09:55 PM
Before you do anything, check to see that both fans are turning. Start at the simple stuff first.
Searching4Sierra
can i use an autozone 180 t-stat, it is about 30 bucks
thecorrectformula
01-23-2007, 10:02 PM
yeah you should be able to. Just make sure that it fits and that the stock T-stat is rated to open at the same temp.
There's not really any difference in brand with thermostats because its pretty simple a spring with a calibrated cylinder of wax in a copper case under the spring.
GOODLUCK with the swap.
kams95ss
01-30-2007, 07:40 PM
my car started to over heat yesterday and I discovered that my fans werent coming on So I ran a fan switch and The fans automatically turn on but that isnt safe because that might blow the fans I believe that I need A waterpump but I dont know
thecorrectformula
01-30-2007, 07:45 PM
The water pump is one of those things that if you think it's going bad, you should replace it cause if it fails your car will over heat almost immediately unless its really cold outside and the coolant doesn't freeze.
CaliforniaBoy5
01-31-2007, 10:57 AM
Call me stupid but i thought t-stats were like 10-15 bucks at the most?
thecorrectformula
01-31-2007, 03:44 PM
Alot of times they are, but it just all depends on the type of vehicle, the brand of t-stat, and the temp settings on it. You may be able to get them for cheaper for the LS1, I haven't checked cause mine was just replaced when I bought the car.
