Question about rim and tire size...
Old 01-24-2007, 10:46 PM
kaos_'s Avatar
Default Question about rim and tire size...
I've got 17x9.5 z06 motorsports on my rear tires but want the tire to stick out a bit more on the sides. i was recommended switching to a wider rim like 17x11. can i still use the 17x9.5 to fit in a wider tire if i use some type of a spacer to fill in the extra width of the tire? i'm just trying to avoid buying a whole new set of rear rims.
Old 01-25-2007, 09:19 AM
Xsta Z 28's Avatar
Widest tire you should run on a 9.5" wheel is a 285/40ZR17.
