4l60e lockup
Old 01-25-2007, 10:12 AM
gman's Avatar
Default 4l60e lockup
Besides better gas mileage and for tuning purposes does it have any other benefits for keeping the lock up function. I personally don't like it and am trying to decide if I want to keep it or not.
Old 01-25-2007, 10:45 AM
LS1Tech Sponsor
performabuilt's Avatar
Well the trans does run cooler in normal driving with lockup, Im not sure but can you tune lockup out all together?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-25-2007, 10:59 AM
Joel_SS's Avatar
Yeah just set the lockup minimum speed to 255mph in all gears..
Old 01-25-2007, 11:01 AM
LS1Tech Sponsor
ok well that wouldnt work for me cause then I would have to try and see if it would lol
__________________
Call 888-744-6542
Old 01-25-2007, 11:22 AM
12secSS's Avatar
Ok, then set it to unlock at 255 MPH and leave the lock up settings stock. Or set the minimum and maximum TCC duty cycles to zero (0).
Old 01-25-2007, 12:06 PM
gman's Avatar
The last time I had my car tuned I had him set the lock up so it only came on when I was on the highway. I think it was set at 65mph. My normal tranny temp. driving around town without lockup is anywhere between 120 to 150 degrees.
Old 01-25-2007, 05:29 PM
Montec's Avatar
When a torque convertor is locked it is most efficient, reducing heat and power loss.
Montec's Avatar
120 is WAY too cold...
Old 01-25-2007, 07:48 PM
gman's Avatar
Why is 120 too cool. Usually when the converter is locked up on the highway it is running at 100 degrees. I thought the cooler the better.
Old 01-25-2007, 09:05 PM
Montec's Avatar
nope, 175 is the perfect temp for a trans. The fluid has detergents and additives that arent active when the fluid is too cold. 100* is very bad.
