turbo lt1 with this radiator?
http://store.summitracing.com/partde...5&autoview=sku
it will fit and the hoses are in the right spot..just have to have one port welded in for the steam pipe..question is..you think this is too small of a radiator with a 550rwhp goal in mine? (t76-10psi)..its shorter than stock..but its alot thicker..and it would be GREAT if i could get it in there to make room for more ****.
I think its a bit small,
I'm doing a truck mani kit and going to cut the core support to free up as much room as I can get
I was looking at one in jegs for $200
over all its like 27" wide 17" tall with two 1" cores
is the one you are looking at 2 or 3 1" cores?
i got a becool rad. thats about 5" shorter side to side then stock and it works fine with my turbo set up....... the only time i had a issue was when i had a powerglide tranny and trying to cruise at 3500rpms it got hot and had to pull over for a few minutes
