Dynamometer Results & Comparisons - 594.5 RWHP on Stock bottom end Turbo and NOS
blackbird345
01-26-2007, 12:05 AM
Well I got 150 hp jets for the nitrous. The TTI single T76 turbo is set to 3 psi but when the nitrous comes on it shoots up to around 6-7 psi. Anyway this is my best dyno ever, previous was 499 with 125 shot but plugs were old. Oh and this is on pump gas running REALLY rich.
SSilverSSurfer
01-26-2007, 12:20 AM
3psi? whats up with that? didnt know it could go that low, nice numbers with the gas
blackbird345
01-26-2007, 12:57 PM
lol yah its the smallest spring I could get. I'm completely scared of blowing her up :-) for more of the rpm range the AFR was in the high 10s then went up to 11 right before redline. I have a 62 N2O and a 35 fuel for the nitrous jets which is also rich as it should be a 33.
On a side note, my cousin just started tuning his car for SD and he gained 15 hp just from the auto ve tuning.
DanZ28
01-26-2007, 01:58 PM
Can you up the boost to get the same whp without the N20?
SSilverSSurfer
01-26-2007, 03:40 PM
you should throw the 8lb spring in there, lol
bad95killer
01-26-2007, 04:03 PM
Damn sounds high on your Stock bottom end buddy i'd just use boost only at 8-10psi to see low 500rwhp if ya really concern about the longevity ;)
peace
boostedbuford
01-26-2007, 04:43 PM
3 pounds of boost....bwahahaha, its just funny reading it.
What did you make with no nitrous and just 3 psi?
blackbird345
01-28-2007, 07:29 PM
Made 407 rwhp on 3 psi but i have s2 h/c so its not impressive...ofcourse the cam is for NA so thats probably not helping...
bandit1
01-28-2007, 09:17 PM
I made 633 rwhp on stock bottom end with 9 psi with procharger didnt like it too much :)
408zo6
01-28-2007, 09:25 PM
i made 590hp on stock bottom end for tw :bang: o year's
blackbird345
01-28-2007, 10:46 PM
Dang so there is a small amount of hope. :-) If not low compression stroker here I come :-)
Slowhawk
01-29-2007, 01:51 AM
The Nitrous is probly worse than the Turbo.Just put the Turbo to 10psi and throw away the juice.
blackbird345
01-29-2007, 04:02 PM
Can't do 10 psi I don't think, I have a 10.8:1 CR,
