Cant Remove pilot bearing
"Blind Hole Puller"
I just change my clutch, slave, and pilot bearing last week. If I were you I would go and rent the "blind hole puller" from autozone(adavanced does not have them). It is similar to a slide hammer except that it has a smaller fitting to be able to fit easily inside the pilot bearing. It took a total of 5 minutes and the bearing was out. I spent three hours the night before with alternative tools with no luck. The deposit is about $145 dollars but you get everything back when you return it.
Originally Posted by Mean Green z28
Or you can do like the old days and stuff the **** out of the hole with wet paper tissure and use an old input shaft and hammer to get it to slip out. Not too good on the thrust bearings though.
From what I have read in here that is not a good idea on the LSX engines due to having a freeze plug behind the pilot bearing and by doing that you will actually push the plug out and into the oil pan. I am sure a search on this will clear up any unexplained detail I might have forgotten.
1 Post
Get a grease gun, and put it up to the hole and use the grease to force it out, it's how we do them at the dealer that don't wanna come out, if we don't feel like grabbin the puller...If you don't have a grease gun, then just rent the puller...
Take a can of compressed air...like people use to clean out their keyboards. Invert it and spray the pilot bearing until it freezes. That will shrink the bearing up slightly and allow your puller to work easier.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOo!!!!!
