trans swap question!!
would i be able to drop the trans off the bellhousing without dropping the k-member down at all? i have an extra trans. just wondering if it would be easier! any help would be greatly appreciated!
you don't need to touch the k-member. once you take the driveshaft and transmission crossmember off the engine will tilt a little bit on it's mounts to give you room to the top bolts.
Moderator
Originally Posted by tici
Is it necessary to remove the exhaust to tilt the engine?
