Fueling & Injection - Bosch 420L fitting sizes
View Full Version : Bosch 420L fitting sizes
Slowhawk
01-27-2007, 02:57 PM
What are the threads on these pumps?
onfire
01-28-2007, 09:10 AM
http://www.atlltd.com/pdf/fuelfilters/KS191%20Bosch%20044%20Pre-Pump%20Filter%20(60%20microns).pdf
This gives the inlet spec. I use that spin on filter....trick piece that works well in a dual intank set-up.
Slowhawk
01-28-2007, 02:47 PM
:confused: The 420L is an inline pump:confused:
whitt1
01-28-2007, 03:08 PM
I did a metric to 6AN adapter on mine ,but I don't remember what size the metric thread was.I'm running a 040 Bosch intank,with a 10AN line to a 10AN x 6AN wye and 2-044 Bosch inline pumps with a separate 6AN line to each fuel rail.
onfire
01-28-2007, 07:23 PM
Bosch also makes a 420L (which is a myth rating) part number ends in "044" that is used intank or inline. I put two in tank.
