autometer tach is way off help please!!!
ok so i have a autometer phantom tach. and its adjustable between 4,6,8 cylinders. i set mine to 4 like i was suppost to but while loging on efilive today i was watching my rpms when i went wot and it was 1000 rpms off. when i was at 6000 on the autometer i was only at 5000 on efilive...
whats going on here?
Did you mean to say you set it to an 8 cyl correct? If so, it might not be that the new tach is off but the factory mass produced tach could be off is more likely. Either way I would def make sure you have it set for the 8 cylinder.
In addition, Has the tach been adjusted to read a 5v square wave signal? I had to send mine back to autometer so they could reset it to read the ls1 signal properly. It took like 2 weeks and I had it back.
when I got mine it was configured as the default which is 12v analog sine wave signal. LS1 uses a 5v square wave signal. Call autometer. They should do it free of charge. I just needed to pay for shipping when I did it.
Auto Meter
High Performance/Pro-Cycle
413 W. Elm Street
Sycamore, IL 60178
Sales 815.899.0800
Technical Service 815.899.0801
Fax 815.895.6786
right on the bottom of contact form for www.autometer.com
good luck.
413 W. Elm Street
Sycamore, IL 60178
Sales 815.899.0800
Fax 815.895.6786
good luck.
