How to launch a turbo car?
Old 01-28-2007, 06:16 PM
blackbird345's Avatar
Default How to launch a turbo car?
Any tips on the best launching technique for a single turbo T76?
Old 01-28-2007, 06:24 PM
02SSLE's Avatar
auto of M6?
Old 01-28-2007, 06:27 PM
kidcamaro98's Avatar
theres really no special way....you launch it like your car was still N/A. Problem is as soon as the boost hits on the top of 1st it always breaks the tires loose
black98ws6ta's Avatar
auto....use transbrake(if equipped) or footbrake to build boost before leaving
m6....needs a 2 step, wired into the clutch petal.....pushing the clutch activates the 2 step, put the gas petal to the floor and release the clutch when the car has built boost. If it needed more or less adjust rpm/tune.
Old 01-28-2007, 07:26 PM
Sorry should have said its a m6. What does the first stage of the 2 step do? Sounds interesting.
Old 01-28-2007, 07:29 PM
A 2 step cuts ignition to a cycle of cylinders. When the fuel isnt burned in the cylinder it goes into the exhaust/headers/manifolds and burns there. This ignition spools the turbo.
Old 01-28-2007, 08:55 PM
Turbo Tech's Avatar
I have set up many customers turbo cars for both a full and pro tree. If the class your racing is a full tree as most are use a 2 step but don’t use the clutch petal switch to activate because if don’t take there foot completely off the gas petal and when you push the clutch in to shift gears and hit the switch again a huge backfire will happen. Put the activation switch somewhere else and use your finger as you would a trans brake. Once your staged press the button go to wot, last yellow comes on let the button and clutch go at the same time. You will need to experiment to get the rpm right but with my experience about 2200 to 2500 rpm works best.
George Scott
Turbo Technology Inc
Old 01-28-2007, 09:27 PM
qqwqeqwrqwqtq's Avatar
I've used a 2-step @4,400 and 10psi boost which has got me 1.49-1.51 60ft's with 27x 11.5 15 hoosier QTP's.
I've also slipped the clutch out at 5k RPM and pulled a 1.56 60ft on 275 40 17 ET street radials.
Either way is hard on the clutch, but it's definitely a balancing act with the gas/clutch as to not bog/spin if you're not using a 2-step.
Old 01-28-2007, 10:43 PM
WOW, now thats amazing!!!!!! This is why i love this board! I've been having a serious problem bogging off the line even with a 150 shot. Where do I get the 2 stage from?
Old 01-28-2007, 10:50 PM
Speed's Avatar
I tried to use a hand held button to launch my old turbo car with an m6. I always seemed to forget to release the damn button in the fray of grabbing for the next gear and working the clutch to ensure it came up well. If you don't use a clutch switch, I recommend a dash or console mounted button that you will release when you reach for the shifter. Might be just me tho.
Old 01-28-2007, 10:52 PM
Mr_president's Avatar
synergy call them they are a sponsor
Old 01-29-2007, 09:39 AM
99Z28LS1's Avatar
good info, i always wanted to know as well
Old 01-29-2007, 09:45 AM
SpaZMaN's Avatar
off topic, but is having a 2-step and a trans-brake the best for an A4 or just the brake?
Old 01-29-2007, 10:02 AM
NA$TY-TA's Avatar
A Trans brake will work to build boost but a 2 step will build boost faster and lets you hold a certain RPM and steady boost... not needing to watch how much gas you give the pedal... Just have the 2 step wired into a Trans brake and just put it to the floor.....
Kyle
Old 01-29-2007, 11:25 AM
SpaZMaN's Avatar
Kyle
ok i understand. another ? if you had a trans-brake, 2-step and stall(lets say the stall locks at 3.8k), would this be the optium(sp) setup?
pre-stage, activate 2-step(2step set right below stall lockup), stage, trans brake, floor it, green and go?
The following users liked this post:
Vince13 (08-11-2019)
Old 01-29-2007, 01:04 PM
6techniques's Avatar
So Synergy is the only one with a two-step right now? Ive been waiting to see the one Halran is coming out with...
Old 01-29-2007, 01:19 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
The 2step is nice because it gives you the ability to select the launch rpm. So far with my setup the 2step is an absolutely neccessity my car is laggy down low.
Old 01-29-2007, 02:02 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
is synergy the only place to get one?kinda pricy for a simple circuit.....
Old 01-29-2007, 02:23 PM
ZL1Killa's Avatar
10 bolt and stock t-56 say BOOOOOOOOOOOOOOOOOOOOOOOOM!!! LMAO
Old 01-29-2007, 04:06 PM
I've got a 9 inch rear but the tranny is kinda getting wierd going in to 2nd...thanks for the advice everyone.
Quick Reply: How to launch a turbo car?
