Sponsored by: DashLynx
Ground effects or lowered?
Old 01-28-2007, 06:45 PM
funkmasta510's Avatar
Default Ground effects or lowered?
I am a new camaro owner so i dont know to much... i was wondering what would be better to do to my car..i have a 96 camaro basic..so should i get ground effects for it and if so which kind? or should i lower it? and if so how would i go about it (basically what i need to lower it and how low should i drop it?) i was planning on putting c6 motorsports on them.. 18x9.5 and 19x10..i appriciate any info...thanx..
Old 01-28-2007, 07:10 PM
kyles2000z's Avatar
lower it. nothin looks worse on these cars than aftermarket wheels with a HUGE fendergap. theres plenty of kits out there, just find one you like i say around 2 inch drop. you cang et away with just swapping the springs, but a lot of people change out the shocks too. and an adjustable panhard bar will be needed to recenter the rearend bc when you drop it the rearend shifts to the passenger side about an inch.
Old 01-28-2007, 07:29 PM
mycamaroSS's Avatar
LOWER IT, and just leave it at that, dont put ground effects, neon, or anything ricer. Just my .02 cents
Old 01-28-2007, 07:41 PM
ProjectCamaro's Avatar
Do both
Here's a picture of my '94. For more checkout RedLS1.com
Old 01-28-2007, 07:44 PM
LILWS6's Avatar
even stock wheels have huge fender gap
Old 01-28-2007, 08:07 PM
Xx01CamaroZ28xX's Avatar
SLAM IT!!!!With those wheels I would run the Hotchkis lowering kit, it will give it a great looking stance and pretty good ride quality. I believe it will lower it about 1.5"......Correct me if I'm wrong guys. IMO I dont like ground effects on F-Body's, looks a little too ricey for me.......Some can pull it off with certain themes, but other than that, i would say lower it.
Old 01-28-2007, 10:15 PM
Droopy8503's Avatar
I Say Do Both And Buy My Body Kit!
Old 01-28-2007, 10:23 PM
What kind od body kit do uy have? And also, so the hotchkins kit would be best? is there anything else i should know if i decide to lower it?
Old 01-29-2007, 10:50 AM
texada's Avatar
put ground effects and lower it about 1.5"
Old 01-29-2007, 11:15 AM
RUDE SS's Avatar
I say lower. Most aftermarket body kits in my opinon =
Old 01-29-2007, 11:23 AM
Breathtaker's Avatar
Most of the guys on here will tell you to lower it...lower it!
Old 01-29-2007, 11:24 AM
what about just some factory RS ground effects?
Old 01-29-2007, 11:31 AM
98Z28MASS's Avatar
lower it ftw
Old 01-29-2007, 01:01 PM
I don't like them.
It would be much better for ya to invest money on some good springs and shocks for the looks, if that's what you are looking for, but you will also get a better ride quality...2 improvements in 1 mod.
Old 01-29-2007, 01:47 PM
jmurray87's Avatar
lower it.
Old 01-29-2007, 01:51 PM
Ls1CamaroGuy87's Avatar
Lowered!! Ground effects look so tacky IMO
Old 01-29-2007, 02:33 PM
angrychicken's Avatar
lower it first then if you find some you like put the ground effects. I know other people will want you to look like them and tell you different. If you do decide on ground effects get something simple. Just remember its your car do whatever you want to do with it. Do what makes you happy. If you do what people tell you. You'll probably regret it down the road.
Old 01-29-2007, 02:42 PM
The SSheriff's Avatar
Don't "Slam It". Use a nice 1.5" front/ 1" rear lowering kit. Looks pretty good. After that, depending on where you live, the car becomes undriveable. Some of the inclines and dips here in Orlando are pretty bad. I don't know where you live Funkmasta, but lower WISELY.
And BTW, the body kits on these cars is Ultra Rice. Stay away from it.
Old 01-29-2007, 02:45 PM
Ericbigmac83's Avatar
+1 and i would def do the shocks and i would also do adjustable lower control arms
Old 01-29-2007, 02:50 PM
So GM is rice by puting the RS kit and the Firebird kit on there cars...
Quick Reply: Ground effects or lowered?
