removing the transmission
Old 01-28-2007, 08:18 PM
half-n-half's Avatar
Default removing the transmission
hey guys i have removed all the bolts holding the engine and the bellhousing together but i cant seem to get it to split open... should i try prying it apart?
just looking for a little helpful insight.
Thanks
Louie
Old 01-28-2007, 09:42 PM
J's99Zrated's Avatar
You have to pry it apart. There are spots to do it at the 9 and 3 o'clock positions. Just try to keep the pressure even and it should come apart.
Old 01-28-2007, 09:45 PM
gametech's Avatar
Make SURE all of the bolts are out. There are a couple that are hard to see and even harder to get to.
Old 01-28-2007, 10:16 PM
ok i will try to do a little prying
and i know that there were a couple of the drivers side that were a pita as well as the one at 12 o clock but i am sure that they are all out now...pretty sure at least i will definitely double check and then try to do a little prying on it
thanks
Louie
Old 01-29-2007, 11:14 AM
kngkahious's Avatar
thanks
Louie
how many bolts are in the bell im pulling my tranny to day or tomorrow i got about 6 outta tranny to bell i was told it is easier then tryin to pull it all at once
Old 01-29-2007, 11:29 AM
WS6GoFast's Avatar
8 in tranny to bell and im pretty sure there are 8 in bell to motor too. There are 2 steel dowl pins at 3 and 9 between the block and bell which tend to sieze up your gonna have to pry them apart
Old 01-29-2007, 05:09 PM
flash12t's Avatar
make sure u get all the bolts out did the same thing. . like they said theres 8 on the tranny and 8 on the bell housing. . the trannying should jsut slide out after u take off the bolts and pry it apart
