car runs like poo
Old 01-28-2007, 10:34 PM
1BAD02WS6's Avatar
Default car runs like poo
i through a code for insuficcient switching of bank 1 sensor2 so i went and bought a new bosch. I noticed that i had drug my 02 extension and the weather packing couldnt get a good seal, i assume water getting on the connection is the problem so i dried it and RTV it for a temp solution but still threw the code and car runs like crapola.
After i have been driving for a few minutes the car starts to, what feels like a misfire on multiple cylinders, and clears up when i reach 4k+ rpms or go wot. Once i have been in the car for a longer period it clears up and goes away. But from idle to 4k rpms i have almost no power.
could the bad sensor cause this??? I also had to change my knock sensors, as one of them craped out.
Thanks
Tyler
Old 01-29-2007, 02:06 AM
ringram's Avatar
Runs ok 4000+ because you are in open loop.
Certainly sounds like your o2 might be dodgy, rtv is a no no with them!
You could just tune open loop and be done with them altogether.
Old 01-29-2007, 07:20 AM
1BAD02WS6's Avatar
lol well the RTV is just a temp solution just to keep the water out..its not actually on/in the connection
Old 01-29-2007, 07:16 PM
1BAD02WS6's Avatar
bump for help
Old 01-29-2007, 07:36 PM
2001NBMZ28's Avatar
Call me a dummy if I'm wrong - but I thought rear 02 codes didn't affect performance? Sure it was a bank1, sensor 2 code?
Old 01-29-2007, 07:51 PM
2xLS1's Avatar
Quit guessing. Get one of your buds to hook up their scanner while you are .
Old 01-30-2007, 09:09 PM
1BAD02WS6's Avatar
i scanned it again today and it pulled up P1153B bank2 sensor 1...thats the sensor i have been replacing...passenger side precat
