Wideband with STD Interface
I ordered my Innovate XD16 wideband w/ gauge set up. When I bought my HP Tuners a few months ago I had different plans and didn’t order the Pro set up. Now my plans have changed and I am my self for not ordering the pro interface. Do you guys think tuning, using the narrow band method and monitoring the AFR via gauge or the log software that comes with the wideband would work ok? I have already tuned my part throttle via LTFT's and I am mostly wanting to use the WB for WOT.
check the stickies... (topic about EGR and wideband) ... the Pro makes it much much simpler , but it's possible to use the wideband with HPT using other sensor inputs.. the top sticky has info about using other sensors (it's specific for EGR, but you can use other inputs)
