Anyone running 220 @ .050"?
I've been trying search for the last couple days, and I can't seem to get it to work. So who has ran one and what was the setup?
XE, XE-R, LSK?
110, 112, 114?
Seems it would make for a great street cam with an efficient high flowing head.
XE, XE-R, LSK?
110, 112, 114?
I have a crane 220-224 which is actually a 282-286 on a 114 with 0.551 lift.
Works well. I wouldnt want power much further up the RPM scale. It will pull itself along idling 800rpm in 3rd gear so torque is pretty good.
The fast90 made a big difference. Go for 1.8 rockers to get the lift up and all should be well.
Ive got the 1.8's... just need to fit them.
Originally Posted by PREDATOR-Z
One of my favorites is 220/220, .581/.581 115+0 (stealth I by MTI)
But it can be improved nowadays
Well since you have ported heads, meaning you can run thinner gasket and mill, I would work on maximising your SCR/DCR.
Since you are 6 speed, meaning you want it to pull nicely into the rpms I wouldn't touch the LSA/ICL but I would cut it on LSK lobes instead of XE-R to get more under the curve.
@ .050 on paper it would be a 219/219 .632/.632 115+0, but in reality once cut it will be more of a 220.x/220.x
since you're putting heads then changing lifters to cadillac or LS7s would not be an issue.
that thing would make a pretty nice flat curve
