Tranny problems..
Old 01-30-2007, 07:27 PM
Pretyflywiteguy's Avatar
Default Tranny problems..
just got the car a week ago and i'm already having major problems I think.. if i'm driving normally (never going above 2K) it drives fine but if i get on it in any gear the motor bogs down and i hear a metal on metal clanking and a strong vibration in the shifter? WTF?
Old 01-30-2007, 08:01 PM
wrencher
wrencher's Avatar
Sounds like you have a drivability issue with the motor not the trans.
Is it pinging & bogging down/ no power?
I would not drive it get that fixed before you hurt it.
Could be a bad fuel pump/low pressure.
Is the SES light on?
Old 01-30-2007, 08:05 PM
not pinging but it does bog down.. no SES. I washed my motor today.. could water have gotten into the opti? i was really careful about that because i dont want to change that until i have to. i would almost rather it be the opti than the tranny.
Old 01-31-2007, 12:40 AM
Blk97WS6's Avatar
Sounds like it could be the opti. My buddies LT1 did that same thing when his opti went out. it drove fine under normal driving, but if he got on it around 4-5k rpms the car would bog down and backfire. he replaced the opti and all problems went away.
Old 01-31-2007, 05:19 AM
i new i shouldn't have cleaned the motor.. but it really needed it! is there anything else it could be or that i should try before spending $500?
**edit**
how could it be the opti if it makes a clanking noise?
Old 01-31-2007, 07:10 AM
anybody?
Old 01-31-2007, 09:32 AM
bump.. anything??
Old 01-31-2007, 10:03 AM
TurboZ28's Avatar
Did it start doing it right after you washed it?
Old 01-31-2007, 11:39 AM
Blk97WS6's Avatar
if its making a bumping noise, its probably not the opti then. hopefully someone else can help you out because im lost.
Old 01-31-2007, 01:11 PM
yeah it fired right up.. I think it was just because it was cold.. it worked fine until the temp. dropped last night because now it's working fine. It was scaring the **** out of me because i just got the car..
