Sponsor Vehicle Projects & Shop Tours - OFI turbo build for customer at the shop...
tt427ls1
01-30-2007, 08:31 PM
Just thought I would share with you guys a build that we are doing here at Ohio forced inductions for a customer. The car was dropped of on the Jan 21st. The car is a 2000 Trans Am with some really nice ccw rims on it. The customer is getting the 98-02 stainless steel turbo kit with the T-76gts. The kit is also going to be air to water. Some of the other upgrades are going to be....
UMI torque arm
UMI subframes connectors
UMI LCA
Moser 9" with a trutrac and 3.50gears (from Driveline solutions..Thanks)
OFI fuel system
60lb Injectors
3" steel Driveshaft (from driveline solutions)
Comp cam
Speed Inc short block
Guages
The customer already has a set of AFR 205's ,fast 90/90 setup, and full suspension all the way around on the car. This should be a fun project when all said and done. I will have pics soon of the stages of the car in process. We already have the 9" setup and ready to go in. The motor should be here next week. Motor is ready to be pulled out. Just the cradle bolts holding it in. Everything is ordered...just waiting for the ups man
