fast questions
That's what she said...
Make sure the IAC motor (top driver side sensor on the throttle body) has the O-ring. It's easy to forget to install it (gets stuck in old throttle body) and can cause an idle surge. When you take it out, clean the IAC plunger and re-install.
Drive the car around a bit and it might figure the idle out. It takes the car awhile to "relearn".
LOL, I feel like an idiot for forgetting the name of it.. lol
I used a long threaded bolt (kind of like the ones that are used to screw the TB to the intake) and sandwiched a piece of metal (between two nuts) branching out to hold the MAP sensor down on the intake to give it some down presure to keep it sealed better.
A buddy of mine told me to do this before hand.. Its alot easier with the intake off then on the car.
His was surging and after he did this, it went away.
ok i would be cool if u had a pic of it so i can understand it better on my intake it just has a place for the map sensor and like a little pocket to the sid e and down of it
No pic, sorry.
Im sure you know you cant even see it let alone get a camera back there.. Maybe someone else will pick up on this thread and maybe explain in better or even have a better idea or a pic even. I have just heard of them leaking back there and well, a vacum leak will cause some surging.
my bad will the map sensor cause a low idle at start up and when u come to a light i was wounding if u heard anything good about eletric water pumps
Not sure with the low ideling. You know you have an idle screw on the TB right? Dont know if that will help or make it worse by adjusting it. Also, it might just need some small tuning adjustment to fix that as well.. just hard to tell.
EWP's. they are rather pricey just to get a few more pony's. If you got the cash then go for it. I have heard mixed reviews. Some say they are suited better for an all out race car then a DD or a weekend warrior though.
i got one i see a big power differance with the intake and the water pump i put 420 to the ground before these upgrades 530 with nos but now it fells like nos power with just motor
the idle screw help out but then it just went crazy its fine when i am in motion those i just got to watch out for it to die at the red lights would not enuff fuel do this to it
