twin turbo ls1 tuning
Old 01-30-2007, 10:49 PM
65ls1's Avatar
Default twin turbo ls1 tuning
Im currently building a tt ls1 t3/t4 what has anyone else run for a contoller and harness.Ex fast,delphi,aim,motec?Whos is the best for my application maybe factory ecu?Its going in a 65 chevelle.Any tt guys achieved this thanks.
Old 01-31-2007, 08:35 AM
Coal Mining Director
onfire's Avatar
850rwhp and down, I would use a 2001 factory ecm and EFI Live with a sd tune...2 or 3 bar. Delete the maf. Use 60lb/hr high Imp Mototron injectors and a great fuel system with a rail mounted regulator and a return line to the tank. If you want more power than that, I would use BS3 so you can go big with low Imp injectors.
Old 01-31-2007, 10:22 AM
Fireball's Avatar
why not an injector driver instead of BS3?
Old 01-31-2007, 10:29 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
65ls1, power goal?
I'm thinking it would be $1500 for stock ecu, custom harness, and HPT... Or $2000 for BS3.
The tipping point is injector size and power goals to me. If you need to run low impedance injectors add $300 for a converter box and I think at that point the better choise is BS3.
Old 01-31-2007, 10:56 AM
Fireball's Avatar
HUH?
stock ecu = free
one can clip wires and run extensions for a few bucks
HPT 3-bar is a few hundred (free if someone buys HPT and uses 2 of the provided credits)
injector driver is 250
This is way less than 1K
Old 01-31-2007, 04:11 PM
onfire's Avatar
Just a personal opinion. For me, If you're going for that much power forget the driver and take the additional safety/benefits that BS3 has in one box.
Old 01-31-2007, 04:17 PM
Fireball's Avatar
I still fail to see what benefit the BS3 gives except for closed loop WB...
I'm building my 1000+ setup around a stock computer
Old 01-31-2007, 04:28 PM
LS1Tech Co-Founder
Brian, he's putting this setup in a 65 Chevelle, reread his post. So I assumed he had to buy a pcm and harness, and I assumed he would buy a premade harness though I'm sure he could buy a pullout harness and ecu for $500. I don't know what HPT 2/3 bar costs but I assume somewhere around $400. So...
Cheapest $1150, priciest $1500
(ecu, harness, injector driver, hpt 2/3 bar).
Old 01-31-2007, 08:36 PM
onfire's Avatar
"except for closed loop WB"........if you say that real fast, it's not much of a benefit....
Plus built in 2 step.
Plus it can drive low imp injectors without worry....a 'converter box' has somw worry built in.
Plus boost control.
Plus map control above 3 bar.
But I hear ya....I ran 710rwhp off a stock ecm last year. Plan on being +800rwhp this year. It's just better to have a BS3 if you're starting with a clean piece of paper and +1000rwhp for better power control on slick tracks, etc. Ask W2W.
Old 01-31-2007, 09:43 PM
Navy David SS's Avatar
Using an AEM set-up on mine. Controls everything, from fuel, ignition..etc, etc, 2-step, progressive boost (leave off 1lb and graduate up to 20lbs by the 1/8th). 3bar, A lot of benefits over the stock. They were suppose to release the LS version soon.
David
Old 01-31-2007, 10:57 PM
65ls1's Avatar
I have heard the benefit to the factory ecu is the self learn capability verses aftermarket, price is a issue but also someone local in oc cal to dyno tune and willing to work with factory ecu.Is wideband nec the most I will probably boost is 14.5 where my internal wastegates are set.I am going to use an aftermarket harness refered to nelsons performance is this a good choice ?Also the map will probably be 2 bar.trying to achieve 800rwhp.The bottom end is stock ls1 block .005 over eagle stroker crank manley rods and custom je pistons.Is 60lb/hr injector the right size for this combo?This is going to be a street/strip car so I will need good driveability.Thanks guys!!!
Old 02-01-2007, 04:56 AM
Fireball's Avatar
Plus boost control.
I'm not familiar with BS3, boost control, I wonder how it compares to a dedicated controller in terms of phased in boost.
over 3-bar, definately a plus, but not too many people have pushed a LSx platform over 30 psi
low-z injectors w/o worry...its the same electronics inside I bet as a converter box...not sure why running one would make me worry...
built in 2-step....single rev limit? Harlans new magic box supposed to multi-limiter w/ retard...once again is the BS3 comprable. Sometimes external items driven by a computer give more functionality (2-step and boost controller in this example)
Old 02-01-2007, 04:58 AM
Fireball's Avatar
Probably less headache going BS3 in that case....didn't see the 65 chevelle part.
Old 02-02-2007, 01:06 AM
65ls1's Avatar
The most ive heard of as far as pushing the lsx is 20psi.I plan on running 14.5.Im not totaly sure yet but im leaning towards factory ecu if I can find someone local to tune ecu with hptune in socal ca.Also with a chassis dyno a big plus!!!Bs3 to my knowledge has alot more custom programing in comparison to stock and really good boost tables which in 3 bar would be a must.Alot of the local tunes in my area a dead set on motec.Very costly but will definately do the job.
Quick Reply: twin turbo ls1 tuning
