View Poll Results: Yes or No
Yes, looks cool, will sound great
96
41.03%
No, looks ghetto even if it does soud awesome
138
58.97%
Voters: 234. You may not vote on this poll
side exhaust poll yes or no rice or nice
Ok here it is. Like it or not. Simple enough to vote. I did this in my section. Had 149 views and only 17 votes. You dont have to explain yourself. Just vote on if you think it looks good or not.
Drgas has a street version of their boom tube now with spin trap built into it. It should look just like this pic. It can be painted black or polished. It should sound mean as hell.
neat..you could really make a good set up with that. what are you thinking 1 per side and 3in to the oval tubing (better ground clearance). will be pricy but deff unique. def keep me updated
Originally Posted by Hawk108
I say no......the only way it would look cool is if it is somehow built into side skirts like one of the camaro race cars had.
you know i also thaught about that for trans am ...taking the side skirts off and mesure a rectangle shape for like some camaro z28 tips maybe not as wide as stock thaugh. Then take and slid it threw the cut you put in the side skirt right before the rear tire.. but i like really loud exhaust thaugh
Clearance should be better with the Dr.Gas piece, but still leading up to it is going to be tight. If you could make it look factory I think it could be a popular mod. Fabrication would be key, as it would most likely have to be custom, unless you could mass produce all the connections.
Moderator
I voted "yes" on potential but needs a little better
execution. Through-the-skirt for sure and as far back
as you can. The more invisible it turns out, the better
(this being the opposite of "rice", producing effect
without show).
without show).
i like it. if you do it right, and it doesnt hang or drag on the ground, i think it should look prety good. id do it in black, im not into the polished bling thing, especiualy since there isnt really anything else on you car it would go with.
