procharger
Old 01-30-2007, 11:53 PM
12345678910's Avatar
Default procharger
how much boost should i run on an lt1 with 95000 miles its going to be a p600b kit and should i upgrade the fuel system too thanks.
Old 01-31-2007, 04:24 AM
EPP
EPP's Avatar
I'd shoot for approx 7 psi if it is intercooled. I'd install a Walbro GSS 340 in tank fuel pump http://www.exoticperformanceplus.com....html?item=777, and upgrade to 42 lb injectorshttp://www.exoticperformanceplus.com/performance_parts/index.html?item=454, then get a dyno tune. Bob
Old 01-31-2007, 04:28 AM
EPP
EPP's Avatar
I'd shoot for about 7 psi if it is intercooled. You will want to install a better in tank fuel pump, such as this one. http://www.exoticperformanceplus.com....html?item=777
You will also want to upgrade to 42 lb fuel injectors. http://www.exoticperformanceplus.com....html?item=454
After this you will need to get a dyno tune. Bob
Old 01-31-2007, 04:38 AM
EPP
EPP's Avatar
Old 01-31-2007, 06:03 AM
thanks
Old 01-31-2007, 06:04 AM
same pats for an lt1 right
Old 01-31-2007, 03:19 PM
would 36 pound injectors be alright
Old 02-01-2007, 05:34 AM
EPP
EPP's Avatar
Smile
Should be at the lower boost level. Check the duty cycle when tuning though. Bob
