What is acceptable oil pressure?
My motor (LS1) is only holding 25 PSI at idle and 35-40 under acceleration. Is this too low or within the acceptable range for a 75k mile motor?
Is it stock? Did you ever take the intake off or played in the back of it?
That is a bit low, but sometimes the sending unit (sensor) play tricks, I would check that first.
Motor is stock - just transplanted it into a Wrangler from a donor car and am running Autometer gauges so I am sure the gauge reading is accurate. Any difference in where the sender is located? I tapped the sending unit into the little bolt on piece near the oil filter - but I wouldn't think you would get any different reading there than on top of the block. And no the motor has not been opened up.
well the stock location for the oilsending unit is on the back of the top of the block.. im not sure if that oil plug has high pressure behind it or not.. i use than for my oil temp. you might want to try and T off the one the computer uses and see if its the same.. if its the same.. you might have an oil pump going south..
did you get the history of the car it came from?
Originally Posted by ohsofast
Why/What would cause the oil pressure to be low
http://www.ls1howto.com/howto/geniii...//IMAGE015.jpg
7.5-10 psi per 1000 is fine, especially on tighter tolerance motors like ls1. in any event, if ur ever in question in the accuracy of ur dash pressure gauge, or the OPSU, hook up a mechanical gauge to it......................
