FS: 2001 Trans Am WS6 6SPD
SOLD
SOLD
Factory Options
- LS1 5.7 L V8
- WS6 Performance Package
- Pewter Metallic Paint
- T-Tops
- Charcoal leather
- Monsoon 10 speaker CD player
- Power: windows, D-seat, locks w/keyless entry, steering
- Cold A/C
Appearance:
- 17 X 9 Chrome SLP WS6 style wheels
- 275/40/17 BFG Comp T/A tires
- Side molding and badge removal
- Tinted Windows
- Rear Pontiac reflective sticker insert
Performance:
- QTP Stainless Steel 1 ¾” long tube headers
- Custom dual 2.5” exhaust dumped before axle w/ “X” pipe
- Richmond 4.10 gears
- MTI Clear Lid w/ K&N air filter
- CNC Ported MAF
- HPTuners Custom PCM tuning
- Hurst short shifter w/ Pro 5.0 short stick
- MSD ignition wires
- Cross Drilled I-rotors w/ Hawk pads
- Spec Stage III clutch w/ billet steel flywheel
- 160* Thermostat
- NGK TR6 Iridium plugs
Suspension
- Goldline Lowering springs (still have stock setup avail.)
- NAPA front struts
- BMR boxed, weld-on subframe connectors, black
- BMR tubular LCA’s w/ weld-on relocation brackets, black
- BMR 32mm front sway bar, black
SOLD
Factory Options
- LS1 5.7 L V8
- T-Tops
- Charcoal leather
- Cold A/C
Appearance:
- Tinted Windows
Performance:
- CNC Ported MAF
- 160* Thermostat
Suspension
- NAPA front struts
I knew your side ground effects looked different, they arent stock TA ground effects, they're the kind that come on some of the V6 firebirds that have a full ground effects package, i've never seen them on a TA until now. Did you put them on there or were they on there when you bought the car?
