Help with horsepower!!!
ok i know this is another one of those guess my horsepower threads but i could really use some input before any major changes to my plans. I already know my turbo is too small for my motor but im just wondering how much power can i make untill i change to a iron block.
MOTOR: 395 LUNATI STROKER STOCK BORE WITH A 4.125 STROKE, 9.3.1 compression
AFR 225 72cc heads
custom grind cam 23x-22x, 58x-58x with a 115 lsa
Ls6 intake with speed inc fuel rails-65# injectors-2 intank walboro 255's,-8 feed,mallory fuel pressure regulator,-6 return line.
Turbo Kit- phamspeed SS header kit not the budget kit. 3 or a 3.5 downpipe not sure which way im going to yet and it goes to a borla catback with no plates. I have a 46mm wastegate,50mm tial b.o.v and i have a e boost 2 as my boost controler
Turbo is a T76Gts ( i know its small but i dont plan on keeping the 395)
BTW its a viper built 6 speed car with a 12 bolt with 3.42s. Guys please help!!! i just want an idea of what i can make before i max this turbo out, its going to make my mind up if i want to keep this set-up for the summer or start building a 370 iron block now.
AFR 225 72cc heads
