General LSX Automobile Discussion Non-technical LSX related topics.
SES CODE, help
Old 01-31-2007, 06:00 PM
BLKWS.6's Avatar
Default SES CODE, help
Does this mean a wire is messed up or is the o2 bad? The code came on one day and I went WOT and it went off, but they still pulled it. Then they cleared it and it is now back (3 days later).
P0157
O2 Sensor
Circuit Low Volts
(Bank 2 Sensor 2)
Is that driver or passenger? Sensor 2 is downstream from the cat, right?
Old 01-31-2007, 06:24 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,460 Likes on 1,053 Posts
B2S2 is the passenger side post-cat sensor.
Old 01-31-2007, 06:43 PM
LS1Formulation's Avatar
Most likely a bad O2. I was lucky, I got a set of 4 for $80. New they're like $90-$120 each
Old 01-31-2007, 06:44 PM
killerinparadise's Avatar
both of mine came on before storage, P0137(drivers) and P0157(passengers) there the sensor's that monitor how your cat is working, you could have a cat that's clogging, or a bad sensor, if you have removed your cat or got long tubes i here they will throw it also, that's all I know just started looking into it though and will be fixing mine when the snow's gone and i can finally drive it again
Old 01-31-2007, 06:47 PM
donalr76's Avatar
Or you could get some headers and turn the rear O2's off. They just detect if the cats are operating properly.
Old 01-31-2007, 06:54 PM
BLKWS.6's Avatar
I realise it is a non-essential item, but I figure I might as well fix it. Wouldn't it throw a code saying "Catalyst efficiency below threshold" or something instead of an O2 code? I was thinking bad sensor...($71.XX at advance auto).
Old 01-31-2007, 07:15 PM
RPM WS6's Avatar
I would guess a bad sensor or pinched/burned wire for a code like that.
Old 01-31-2007, 07:30 PM
BLKWS.6's Avatar
I will visually verify the integrity of the wire and if it looks ok, get a new O2.
