front end swap
front end swap
i am doing the front clip conversion. can anyone tell me how the hell to pull the fenders off and put them on without scratching them and without taking the doors off. thanks
quite easy, theres a bolt on top by the winshield, 2 on the bottom of the fender, 2 nuts and 1 bolt that hold the bumper and fender to the brace, you will have to take the splash shield and inner fender out or loose, theres a bolt thats straight back behind the wheel behind the inner fender,a nd then there are some inside the hood area , all you need is a 10mm socket, ratchet and extension, on the 93-97's thers also a torx 30 by the headloght that holds the bumper cover back
