A couple question
A couple question
Building a custom built turbo kit for my LT1 where is the best spot to put the two o2 bungs at? Also I see some people that run those flex pipes.. Is there any big benefit to that besides bein able to move it a little bit? And last does everyone run 2.5inch piping on there kits? When is it nessicary to run anything bigger?
about 8" out on the dp..........if you run solid motor mounts you don't need a flexpipe..typically......and you can use 2 1/4 crossover piping if you what to, but if ats a large frame go with 2 1/5.
