I need to know how to fix these codes please!
My SES light is on and my inspection is 5 months out of date...I need the car inspected ASAP, but I don't know what I need to fix in order to fix these codes. The trown codes are:
P0410 "secondary air injection malfunction"
P0412 "secondary air injection valve A malfunction"
P0418 "secondary air injection relay A malfunction"
P0420 "catalyst efficiency below threshhold (bank 1)"
P1416 "manufacturer's controlled auxilary emissions control"
What do I need to do to the car to fix it and get rid of these trouble codes?
Thanks.
Thanks.
If you still have AIR, first thing to check for the first 3 codes is the AIR PUMP fuse under the hood. P0420 is a bad drivers side cat or rear 02 sensor. The last one is a bad/clogged passenger side air check valve.
