Those with the air/egr delete Q?
Old 02-02-2007, 05:23 PM
Emoney97ss's Avatar
Default Those with the air/egr delete Q?
When you delete both of them from the car is it a must to put the filter where the oil fill cap is? I'm about to change to headers and the ls6 manifold and figured i'll get ride of it all!!!! but don't want to hurt anything in the process...
Old 02-02-2007, 05:25 PM
dmart's Avatar
You only need the filter on the oil cap if you are deleting the PCV system. EGR and AIR have nothing to do with the PCV.
Old 02-02-2007, 05:32 PM
Bill Bowling's Avatar
I agree.
Bill
Old 02-02-2007, 05:34 PM
That's what she said...
TheBlurLS1's Avatar
You can keep AIR with the LS6, but you're going to get coded for EGR untill you tune it out anyway, might as well yank 'em both!
They are correct on not needing the breather setup, that's for !PCV.
Old 02-03-2007, 01:17 PM
Emoney97ss's Avatar
ok my bad i guess i'm confused about what is what then what the hell is a pcv?
Old 02-06-2007, 01:04 PM
lsx24's Avatar
PCV stands for "Positive Crankcase Ventilation", and is your evacuation system used to vent pressure build up. It has nothing to do with EGR/AIR. People who run catch cans are adding functionality to their PCV system, so it traps oil in addition to venting pressure.
Old 02-06-2007, 01:16 PM
Tainted's Avatar
the filter on the oil cap is only if you delete the PCV system but you could do it anyway
