underdrive pully
Old 02-02-2007, 11:55 PM
Ta'sWs602's Avatar
Default underdrive pully
so i found this slp underdrive pully for 140 bucks is that a good deal with a new bolt how can i tell its a slp underdrive pully the guy says it is but i havent looked at it yet does it really make more power thanks for the help trevor
Old 02-03-2007, 12:09 AM
Tainted's Avatar
slp asp theyre all good pulleys as far as price I got no idea. it wont give you that much of a gain but hey every bit helps
Old 02-03-2007, 07:05 AM
Red99TA's Avatar
easiest way to tell is to see if it's smaller than your stock pulley. I can't remember how much they are new but I think it's around $200 or more. It's more of a freeing up horsepower mod. Definitely frees up torque as there's less drag on the motor.
Old 02-03-2007, 09:36 AM
On the tree
Sneakyws6's Avatar
Wont give you much hp gain???
You dont think a increase of 8rwhp for $140 is much of a gain?
That is a good deal on SLP pulley. I just bought mine last summer and it was right at $200 for the pulley and the bolt.
Old 02-03-2007, 09:38 AM
dpw41285's Avatar
avg is 8-10 rwhp i would do it for that price...it should be 25%SMALLER
Old 02-03-2007, 10:01 AM
Restricted User
98Z28CobraKiller's Avatar
I am curious, do you see the same gain regardless of your starting point?
For instance, if you see 8-10 rwhp on a fairly stock setup, do you still see the same 8-10 rwhp on a 500 RWHP car or do you see more or less?
Old 02-03-2007, 12:56 PM
ricernomore's Avatar
Old 02-03-2007, 03:07 PM
z28convert's Avatar
a local gained guy 15 rwhp with an slp pulley in his tr224 cammed m6 ls1
Old 02-03-2007, 05:21 PM
bad6as's Avatar
kinda off topic but is the asp 25% ud pulley the lightest?
Old 02-03-2007, 07:25 PM
10 Second Fun Car
jlrz28's Avatar
Have him take a picture of it with a tape measure across it then compare it to your stock one. There isnt really much to be gained with the pulley imo but it doesnt hurt.
Old 02-04-2007, 12:58 PM
N4cer's Avatar
From all the LS1 modders I've talked to, it's more of a bragging and dyno queen mod. They all agree you'll notice nothing in actual track times from it. But personally I'll still pick one up eventually. It's just nowhere near the top of my priorities list.
Old 02-04-2007, 02:40 PM
Moderator
davered00ss's Avatar
It was 12rwhp & 12rwtq. But close enough. I paid $210 ish for it shipped from Speed inc., Well worth while mod.
Old 02-04-2007, 02:43 PM
Moderator
A pully is a well worthwile mod. ~10rwhp for $200. Probably the cheapest hp you will find.
Old 02-04-2007, 02:56 PM
z28ss4me's Avatar
Picked up a full tenth in the 1/4 with my ASP.
Old 02-04-2007, 04:48 PM
Restricted User
Aside from a couple of $6 jets for fuel and nitrous that is
Old 02-04-2007, 05:00 PM
cav101's Avatar
picked mine up with a belt for 150......140 is defiantely a good deal. I'd only do it if you were doing a cam at the same time.
Old 02-04-2007, 05:03 PM
Hodgesz28's Avatar
As stated above every little bit helps and for 140.00 bucks 8-15hp is that much more then you had before!
Old 02-04-2007, 05:04 PM
N4cer's Avatar
Are these numbers you guys have from your own before/after dyno results from an accurate dyno? Or are these regurgitated manufacturer claims?
Old 02-04-2007, 05:30 PM
Tainted's Avatar
after I get my ported TB I'm gonig for a UD pulley but im gonna get an voerdrive alternator one with it
Old 02-05-2007, 09:27 AM
FU_I_AM_UltraZ's Avatar
i did a b4 and after dyno b/c i wanted to see how much the 25% underdrive would actually give me. 2 rwhp. after shipping and the belts... it was over $200. so... a recap... $100 for 1 rwhp.... should have saved my money.
