ls2 flywheel resurfaced, problems finding shim!!! please help
Old 02-03-2007, 12:10 AM
nahasapeemapetalon's Avatar
Default ls2 flywheel resurfaced, problems finding shim!!! please help
I just put in my ls7 clutch and ls2 flywheel about 4 months of driving ago.
I think a faulty master cyl. has caused excessive wear. Machinst took off 20 thousandths from the flywheel resurface and said i needed a 20 thou. shim for the clutch or rather flywheel. I dont know where to find one, is it standard etc....
The parts store said they had a chevy 350 standard one for 50 thou. i would assume too much?
PLEASE HELP WITH ADVICE
Old 02-06-2007, 12:39 PM
I found universal shims that would work in summit and jegs, both 30 thousandsths.
I have read and heard that .020 is the fine line for getting a shim or not.
Most people I have talked to have no idea, not too many ppl have experience with this i take it?
Old 02-07-2007, 10:45 AM
Well i ordered a standard gm shim for .025 which is a little more then what was taken off but Im guessing it will work. I am just going to put it in since i havent gotten an answer from fred beans or other.
Old 02-07-2007, 06:40 PM
03 BUSA's Avatar
You could always use a washer inbetween the slave and trans.
Quick Reply: ls2 flywheel resurfaced, problems finding shim!!! please help
