a few parts for sale in the mesquite area?
I have 2 silver 99' vette wheels with well worn nitto DR's on them one is showing threads bad though $150 for both.
and this!
Air-Temperature Module, Various V8 Applications (Call)
This module plugs in between the air temperature sensor and its harness connector. It tells the PCM air to provide maximum spark advance (usually a 1 to 2 degree increase). Proper knock sensor and other engine sensor functions are not compromised. SLP suggests the use of premium grade fuel with this modification. A 5 to 7 horsepower increase is possible. Call for the most up to the minute vehicle applications. This item works on stock or modified engines, HOWEVER, it is NOT for use with custom PCM calibrations with advance spark timing. NOT legal for use on pollution controlled motor vehicles.
NOTE: For use with stock MAF sensors and stock tuning. $15
I also have a K&N filter for a 03'GT mustang $25 used only about 2 weeks!
also 1 Chrome Cobra R wheel with 275-40-17 tire (wheel has cracked lip but still holds air great) $75
PM me if your ready to buy! hopefully all local sale's though?
and this!
