Where To Buy T/A Gage Cluster Lens (Other Than GM)?
Originally Posted by 1QUIKWS6
NE1 know where to get a T/A Gauge Cluster Lens other than from GM?
Need a spare for a project
If you mean just the TA Bezel, you cannot get them from GM. They are a discontinued part. I used to have 2 cases of them, but we've sold them all.
Ah yes, I remember now - you were the one selling them. Funny how GM discontinues parts that you always need
None to be found anywhere then? Really don't want a used one since it would probably already have the normal scratches from people removing them and not taking care...
The clear lens is plastic welded to the black part that you see thru the lens that surrounds the gages when installed to form an assembly - they are not easily seperated.
The assembly is seperate from the gage cluster however, and can be removed.
I want a new, pristine lens without scratches - used one won't cut it as most people are not careful when they remove the gage cluster from the car and gouge the living snot out of the plastic lens getting it out past the steering column or when removing/installing the black plastic gage bezel...
Originally Posted by LS1obsession
You could probably contact MacEwen Motorsports or WS6Store as they sell the t/a bezels with the Camaro kits. Maybe you could buy it separate?
If they are discontinued from GM they must be getting them from an aftermarket supplier.
