stock bottom end safe RPMs for new cam?
Old 02-04-2007, 08:27 PM
Cchris1109's Avatar
Default stock bottom end safe RPMs for new cam?
New cam says powerband from 1800-6400
can i raise rev limiter to 6400 safely on stock bottom end and automatic transmission
if not 6400 what is safest to do?
Old 02-04-2007, 09:23 PM
caviness's Avatar
everbody says change rod bolts. for 98,99 stock bolts 6200 max i think,00,01,02 ok to 6700.
Old 02-04-2007, 10:00 PM
SSNISTR's Avatar
I have my limter set at 6700, but my shift light set at 6400.
Old 02-04-2007, 10:25 PM
yak
yak's Avatar
I spun my 98 to 6950. I had stock rod bolts and a fully stock bottom end. i think 6400 is safe.
Old 02-05-2007, 02:49 AM
Cchris1109's Avatar
cool anyone else think 6400 is safe
Old 02-05-2007, 10:31 AM
jmm98LS1's Avatar
I shift my 98 with stock rod bolts at 6400, limiter is set at 6700.
Old 02-05-2007, 10:47 AM
bjamick's Avatar
Ya ive heard that LS1s are good for 7k rpm so dont worry bout it im bout to be shifting my 99 at 6600-6700...
Old 02-05-2007, 12:42 PM
purdueranger's Avatar
Rev limiter at 7k and shift at 6700.
Old 02-05-2007, 04:21 PM
bad6as's Avatar
when i do the h/c swap ill have a 6600 rev limit shifting at 6500 because of the rod bolts and oil system
Old 02-05-2007, 05:28 PM
CARTEK Racing
WS6TransAm01's Avatar
I think with all the $ we invest into our motors a set of rod-bolts is a small small price to ay for peace of mind.
I spin my stock bottom end with ARP Rod Bolts to 7200, shifting at 7000rpm.
Old 02-05-2007, 05:30 PM
Blown2000SS's Avatar
just get rod bolts, worth the peace of mind.
Old 02-05-2007, 06:58 PM
Studytime's Avatar
And to make you feel better, my '98 sees 6600 on the stock bolts and it's never chunked a rod or spun a bearing.
Ben T.
Old 02-05-2007, 07:13 PM
bobodog's Avatar
holy shnykees!! i thought going to 6000 was pushing it. can you go 6700 on stoock motor?
Old 02-05-2007, 07:50 PM
NemesisC5's Avatar
Spinning my stock bottom to 6600 for 6000 miles with no problems. Going to raise rev limiter to 6900, shift at 6800 and pray.
Old 02-05-2007, 08:15 PM
nikon1999's Avatar
my stock bottom end 99 shifts at around 6700 and the rev limiter is at 7100... due to my superb traction on the street it sees 7k+ to often when i throw my k-member in im going to do rod bolts though..
Old 02-05-2007, 08:48 PM
SSNISTR's Avatar
The STOCK limiter is over 6000....
Old 02-05-2007, 08:59 PM
treysamws6's Avatar
I shift mine at 6400, red line at 6700
