Road Racing - coolant.. what are you guys using?
GR33N GoblinM6
02-05-2007, 02:53 PM
what coolant are you guys using in your system? Standard Dex-cool? the green stuff? Straight water? Water with Water Wetter?
i want to be sure i can use the best stuff possible.. come summer time the temps are the local track are 90-100 for air.. and 140* tarmac temps
NHRAMAN
02-05-2007, 02:56 PM
Dex-cool for 7 years and 3 changes..no problems at all.
DONAIMIAN
02-11-2007, 08:36 PM
Distilled water/water wetter.
Killer_Bluebird
02-11-2007, 10:46 PM
Dex-cool on the street and Distilled water/purple ice on the track.
gnx7
02-12-2007, 05:49 PM
1 bottle of Redline Water Wetter, distilled water, 1 bottle of RMI-25. Make sure all the bubbles are bled out of the cooling system. Then repeat 2-3 times.
GPM30236
02-20-2007, 11:59 AM
Evans Npg R , saw 316 oil temps this fall at vir with 212 coolant temps.
smit2732
03-17-2007, 08:31 PM
distilled water and 2bottles of water wetter. car doesnt see below 35deg temps.
Ojustracing
03-17-2007, 10:37 PM
GO-5. I dont like dex-cool work with it everyday but that a whole other discussion..
John
mitchntx
03-18-2007, 04:45 AM
John
Listen to this guy ... cooling is his business.
JudgeGuns
03-28-2007, 12:51 AM
i use redline water wetter...runs engine 20' degees cooler, doesn't get cold enough here for antifreeze :)
yeah i agree dexcool sux ! :judge:
TexZ
03-28-2007, 09:25 AM
John
What is GO-5?
JudgeGuns
03-28-2007, 11:48 AM
What is GO-5?
YEAH!! WAZZZATTT ???
dailydriver
03-28-2007, 05:51 PM
Newest spec Daimler Chrysler (among many others) antifreeze/coolant. It's on the shelf at Peppies and elsewhere, albeit slightly more $$$ than Dex Cool.
JudgeGuns
03-28-2007, 06:12 PM
thx ! :cheers: :cheers: :cheers:
kill_machine85
03-31-2007, 12:41 AM
i like to run what ever is on sale at walmart
sawedoff
04-27-2007, 05:54 PM
Evans Waterless
Rescue Ranger
04-27-2007, 06:30 PM
Dex-cool user here.. though just starting to really race it, so we'll see. This car does indeed see a lot of COLD temps
JimMueller
06-11-2007, 11:41 AM
So for those of us who don't have to worry about freezing temps, does running distilled water w/ water wetter pose any water pump lubrication or block corrosion concerns?
What's the installation procedure for above? Add the two bottles of WW, then top off with distilled water as necessary? Do I need to perform a coolant flush first?
mitchntx
06-11-2007, 12:37 PM
Jim,
NASA banned the use of glycol based coolants. I've used distilled water only in my LT1 without any issues. since 2004.
Now, I have evacuated the cooling system a time or two ... ;)
andrewdruiz
06-11-2007, 02:05 PM
75% Distilled water
25% Dexcool
Water Wetter
Normal temps on the track are ~210 water/ ~215-220 oil. Highest I saw before I changed to a Taurus e-fan was about 235 water/ 240 oil.
