Fueling & Injection - what glue to use for fuel pump bucket
christsbane
02-05-2007, 06:35 PM
I finally got tired of my camaro broken down sitting in my driveway so I finally started to finish replacing my fuel pump, but the kit never came with any glue. I know that gasoline will eat away most glue, so what would be safe to use to get my bucket back together. Also, how important is it to keep the bucket? Say i toss the bucket and let the pump hang, as long as i never go below a 1/4 tank will i be fine? Thanks in advance.
Jake@EPP
02-05-2007, 07:45 PM
Im not sure what glue your refrencing to. Are you talking about the tank seal?
Argon Z
02-05-2007, 07:51 PM
do NOT use silicone
christsbane
02-05-2007, 08:34 PM
in the racetronix lt1 fuel pump install http://www.geocities.com/formulapower2/fuelpump.html , he talks about glueing the bucket back together, but i'm not sure what kind of glue to use since i'm not using a racetronix kit and mine never came with glue
Racetronix
02-05-2007, 09:06 PM
Glue is only required for LT1 applications. LS1 does not require glue.
christsbane
02-06-2007, 05:26 AM
it is an lt1, also do you think jb weld might hold up?
christsbane
02-06-2007, 01:25 PM
anyone?
Fire67
02-07-2007, 03:10 PM
jb weld is fine, used it and lasted longer than the pump.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
