Generation III Internal Engine - pushrod length
View Full Version : pushrod length
mcfarlnd
02-06-2007, 05:29 PM
i have a 2007 4.8l rcsb
i would like to get a cam with the specs: 216/220 112LSA +4 .561/.564. also i want a thinner head gasket of .42 rather than the stock .52. what size push rods would i need? or is this something im going to have to check when i have it assembled in the truck.
LS1MCSS
02-06-2007, 06:12 PM
You would be better off to check for the correct length. Do a search for pushrod length checking and there are threads that tell you how.
mcfarlnd
02-06-2007, 10:14 PM
thanks for the help
JPH
02-07-2007, 11:35 AM
stock length.
mcfarlnd
02-07-2007, 06:57 PM
how is that when the head gasket is going to be thinner?
JPH
02-07-2007, 07:45 PM
.010 more preload, the motor will like it. (valvetrain that is)
mcfarlnd
02-08-2007, 10:17 PM
are you joking or serious?????
mcfarlnd
02-08-2007, 10:18 PM
explain.....
Mean Green z28
02-09-2007, 01:18 AM
That .010 isn't enough to get a different pushrod length. The hyd. lifter plunger will absorb that .010 with not much effort/effect. Measure the preload on the rocker bolts after you get the cam in and with the stock lifters, if you get somewhere in the 1 turn (+ or - 1/4 turn) range, you should be good to go.
mcfarlnd
02-09-2007, 02:09 PM
i just dont want something to get jacked up. i dont want to be guessing around. ill try that and if it dont work ill just measure it.
JPH
02-09-2007, 04:23 PM
stock length.
Ryan02SS
02-09-2007, 04:37 PM
With these non adjustable valvetrains you have to adjust pushrod length to make up the differences. To maintain proper valvetrain geometry it's a PIA with a non adj valvetrain. More than likely your new cam will have a smaller base circle than your stocker. Find that number out and subtract from your stock basecircle. Add that number plus .010 for your gasket and that will give you a calculated length to add to your stock pushrod. This will maintain correct valvetrain geometry with a non adj setup.
You can use your stock pushrods and be fine, but you will no longer have correct valvetrain geometry as the lifter is soaking up the discrepency of the pushrod length.
You want correct valvetrain geometry to keep the rocker tip with a perfect sweep pattern across the top of the valve stem. With a adj setup it's very simple to adjust this.
You can also use a pushrod length checker to verify.
mcfarlnd
02-10-2007, 12:53 AM
wouldnt i need to subtract .010 since the gasket is smaller than stock?
sorry for all the questions and thanks for the help.
Ryan02SS
02-10-2007, 10:17 AM
Correct. Not add my mistake. Too many thoughts and I can't keep up with the typing.
PREDATOR-Z
02-10-2007, 11:39 AM
7.400
mcfarlnd
02-11-2007, 05:11 PM
7.400
do you mind me asking how you got that number?
