Sponsored by: DashLynx
anyone do the sequential tails module??
Old 02-06-2007, 08:28 PM
ws6transamws6's Avatar
Default anyone do the sequential tails module??
title says it all
Old 02-06-2007, 08:58 PM
emerica4601's Avatar
Location: king of prussia, pa (home) and williamsport, pa (school)
ttmft
Old 02-07-2007, 04:25 AM
1QUIKWS6's Avatar
Yup, got mine from blinkblink.com Did the 3rd tailight bulb conversion (added a real flashing bulb to the outer light on each tailight) so there are (3) lights on each side that sequence instead of just (2). This entails changing out the socket for one like the others and modifying your housing for the socket to fit.
You will also need to get a HD Electronic Flasher Module to replace the stocker for them to flash properly. They can be found at any auto parts store.
Old 02-07-2007, 11:56 AM
onefastbird95's Avatar
there is a nice kit on ebay that has EVERYTHING needed for installation. It is the best bang for your buck
Old 02-07-2007, 01:00 PM
Kev98Ta's Avatar
There are kits out there that will give you a 3 light sequence with out the hassle of having changing sockets. Trust me.
Regardless you will have to upgrade your flasher module.
Old 02-07-2007, 01:07 PM
is there a cheap way to do this mod? is it possible to wire up a buncha stuff from radioshack and get the same result without spending the 80 some dollars for the ones on ebay?
Quick Reply: anyone do the sequential tails module??
