MTI cam on stock z28
Old 02-07-2007, 01:48 AM
F-Killer's Avatar
Default MTI cam on stock z28
Hey guys, Im getting a mti x1 cam 230, 227, 591, 571 112 lsa and comp 918 springs on a A4 2000 z28 with, my car is stock I just got loudmouth I exhaust and k&n filter, what else do I need? (pushrods,retainers), and what's the best I can get? I dont drive it too much, its not a daily driven car.
Im also installing pacesetter ypipe and headers, 3.90 motive gear, transgo and transcooler soon
Thanks
Old 02-07-2007, 03:40 AM
PREDATOR-Z's Avatar
Stall for sure, p-rods and spring locks, of course some gaskets, and LS6 oil pump + LS2 chain.
http://www.ls1howto.com explains a lot of the necessities
Old 02-07-2007, 01:34 PM
F-Killer's Avatar
Thanks, which pushrods and spring locks would you recommend me? do you think an ls2 chain would do or should i better get a double chain? to make a double chain conversion, do I only need double cam and crank gears?
Old 02-07-2007, 01:40 PM
Wheeler99WS6's Avatar
I would think the LS2 timing chain would be sufficient, that is what I plan on going with after alot of research. As said before I would look into getting a TC and have it stalled around 3200-3600, to get you into your powerband.
Old 02-07-2007, 02:49 PM
F-Killer's Avatar
Thanks, so which pushrods and spring locks would you recommend me? I was looking for pushrods and found different sizes and dont know which one would fit the best my car
Old 02-07-2007, 04:12 PM
stock size pushrods would work, they are 7.4", go for some chromoly hardened pushrods. Titanium retainers seem to be common addition when doing cam install.
Old 02-08-2007, 03:30 PM
F-Killer's Avatar
Should I buy new inyectors, ive got the original ones 26 lbs, which one would you recommend me to get? i am not buying heads
Old 02-08-2007, 04:21 PM
bad2000z's Avatar
Your stock injectors will be fine. I still have the stock ones in my car with heads/cam.
Old 02-08-2007, 05:04 PM
00T\A's Avatar
I'm sure you know you will also need a tune.
Old 02-08-2007, 05:36 PM
F-Killer's Avatar
Yes for sure, im getting 3.73 gear so Im getting a tune for both the cam and the gear, thanks guys, any other recomendations?
Old 02-08-2007, 06:32 PM
john563's Avatar
more gas money
Old 02-08-2007, 06:36 PM
Cchris1109's Avatar
Originally Posted by john563
more gas money
haha good one!
Old 02-08-2007, 07:12 PM
F-Killer's Avatar
Yes I know, but I dont use the car much, I might take it out twice a week as much, so its not something to worry about jajaja
Old 03-11-2007, 03:06 PM
aleSS's Avatar
You need 7.425 pushrods, jajajajajaja, just kidding!!!!
