Cheatr Cam w/D1SC?
i cant answer how it would work with a supercharger, but i have it on my STS set up and it makes good power, some people tell me to change it that is not a good turbo cam, other say it works good. it is a low overlap cam so for turbo application that is good, im not as knowledgable about supercharger needs.
I would have to say it would be an awesome blower cam seeing that the specs for the cheatr 214/230 .601/.578 117 LSA are nearly identical as the specs on TR's blower cam 214/230 .601/.575 117 LSA but to be absolutly sure I would just go ahead and ask thunder racing themselves since they do make both cam's
Have a blower cam from TR on the way. Will be running D1SC at 10psi with a ton of other mods. Shane in tech is the one you want to talk to. He is the one who recommended this cam and seems to know his ****. Not as extreme as you could be but should supply good power. I have a vert and this was part of the equation. Car should be 650-690 RWHP when tuned. Good luck.
