General LSX Automobile Discussion Non-technical LSX related topics.
Turn signal wont work.
Old 02-07-2007, 01:43 PM
Onez4u2bn's Avatar
Default Turn signal wont work.
I got a dumb question. My left turn signal wont work. I flip it to signal a left turn and the light on the dash just stays on. It doesnt click or anything. The daytime running lamps on the same side do not work also. However if I turn the switch inside to turn my lights on manually both bulbs on the left side signal come on. Any ideas? Right side works fine. I'm not very good at little things like this mainly because im afraid of messing something up. Any help is appreciated.
Old 02-07-2007, 01:48 PM
02white6.0's Avatar
I had a similiar problem a while back, but it was both side for me, wound up being the fuse.
Old 02-07-2007, 02:41 PM
aaron653's Avatar
this happened to me...the bulb was loose and it would work sometimes but not others,so i bought another bulb and it fit better and still works
Old 02-07-2007, 02:43 PM
bjamick's Avatar
Ya the bulb is out or the relay has went bad. both are cheap
Old 02-07-2007, 02:59 PM
Onez4u2bn's Avatar
Thanks guys! Where exactly are the relays?
Old 02-07-2007, 03:10 PM
BirdsOnly's Avatar
How about a blinker unit? Do these cars have them, if they do that is what it might be.
Old 02-07-2007, 03:11 PM
99Z28LS1's Avatar
did you try putting new fuid in it? thats prob why...... j/k
yeah, i would say try the relays...... when i first bought my car in dec 03' the turn signal would just stay on
but she was under warranty so i sent her off to fix the "little" things that were wrong with her and she came back good as new. and now she's got a little whistle to her......
Old 02-08-2007, 09:56 AM
bjamick's Avatar
Actually its prob just the bulb, bc mine did the exact same thing and its a way for the car to tell you your bulb has went out.
Old 02-08-2007, 10:27 AM
craz28's Avatar
/\/\ what he said, had the same problem too.
Old 02-08-2007, 10:45 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Just stop turning left
Old 02-08-2007, 10:55 AM
ZFan88's Avatar
Old 02-08-2007, 02:12 PM
Copy & Paste Moderator
VIP1's Avatar
The bulbs are dual filament.
* Dim filament for parking lights.
* Bright filament for signals.
That is why they still lit up when you turned on the parking lights, but they didn't work when you used the signals.
The 4th gen f-body has two flashers.
* One for left/right signals
* One for hazards
Therefore, if one side works and the other doesnt, then the problem is not the flasher.
Turn on the hazards and walk around the car. Replace the bulbs that don't flash. The problem could also be a corroded socket and not the bulb.
Old 02-08-2007, 02:29 PM
MjMaro's Avatar
I had the same problem a while back, gave it a good smack and havent had it happen again.
