question about the actual stock pcm programming
Old 02-07-2007, 02:41 PM
96ta's Avatar
Default question about the actual stock pcm programming
is the programming in the 02 ta m6 is the same as an 02 z28 m6? im wondering cuz i have the diablo sport tuner and i was going to put the performance tune on my buddies z28 but i didnt want it to overwrite my pcm programming if they were different.....thanks
Old 02-07-2007, 02:48 PM
LS1TECH Sponsor
foff667's Avatar
I just opened an 01 camaro Z28 a4 file with hptuners & compared it against an 02 trans am a4 file & found only 5 minor differences so take that fwiw.
Old 02-07-2007, 02:49 PM
96ta's Avatar
Originally Posted by foff667
I just opened an 01 camaro Z28 a4 file & compared it against an 02 trans am a4 file & found only 5 differences so take that fwiw.
hmmmmmmm....i dont know much about tuning and if its not exactly the same ill probably wont do it.....no sense in screwing up my car.
Old 02-07-2007, 03:56 PM
slow's Avatar
read the part number, but provided the same tranny/axle ratio, they may be the same.
I know the latest updates for the 2001 hawk, and 2001 Z28 I recently tuned, used the same stock file, both 3.23 A4 cars.
Ryan
Old 02-07-2007, 10:25 PM
96ta's Avatar
Ryan
where would this part number be you mean on the tuner?
Old 02-08-2007, 12:20 AM
horist's Avatar
same vehicle, different shells (an 02 camaro z28/ss m6 is the same drivetrain as an 02 firebird transam/ws6/firehawk m6 ... only difference is the external looks and some internal looks... firebird and camaro are the same just look different)
only difference would be tire height (and I believe they're negligable... but i'm too tired to verify)... but a 3.42 rear gear stock camaro is the same as a 3.42 rear gear transam....
why would you flashing your buddies car mess up your pcm?
are you trying to use your tuner to write to both cars? if so... I don't think that's allowed (but never used a diablo sport tuner.... you are using a predator right?)
Old 02-08-2007, 06:23 AM
96ta's Avatar
yea i was going to flash his car with the same tune in mine.....
Old 04-01-2007, 02:41 PM
thingthatgoes's Avatar
I am sure that I am repplying too late but...
You can only tune one car with the Diablo Sport. To work on another VIN you have to have it " reflashed" by Diablosport. I think that costs $100
