TEA heads with a G5X3 cam ??
Is it possible to run TEA 5.3 stage 1.5 heads with the G5X3 cam and NOT have to flycut?? I have read good things about their heads so do yall think this will be a good set up on a 02 MN6 vette ?
Originally Posted by 02blackbeauty19
Well should they be milled and to what specs. and what size gasket and valves? I mean I will flycut but want to avoid it if all possible. Thanks guys
Not hard, here is a pic of mine almost ready. I did smooth the cut down, just incase anyone starts askin.
Originally Posted by DONAIMIAN
Is that the original motor in the car? To say its a 99 that came with graphite gaskets, you really got the deck clean.
I rented LGM's dummy head to nothch the pistons.. Very straight and easy to do if you decide to do it.
Sure whatever pistons I use will already have valve reliefs.
