Stereo & Electronics - Mounting amp on HUMP in Hatch
View Full Version : Mounting amp on HUMP in Hatch
dirtyblackhoe
02-08-2007, 08:34 AM
I just put a small amp and subthump in my car and I love it, but where the shop mounted the amp on the back deck, the screws didn't hold because they put in screws that were like 1/4" long. Can I just get a slightly larger screw to put them there, or do I have to worry about the gas tank. I searched and it seems like most people put a piece of wood under the carpet and then mount the amp to that...wouldn't the wood still move? Can I not just screw it in? Please post pics and any advice on the subject. Thanks.
MikeFbody
02-08-2007, 09:47 AM
yes, the gas tank is right under that metal. The shop that installed your amp should not have drilled there, as it's very easy to puncture the plastic gas tank.
so, you definately do not want longer screws.
I would use a liquid contrsuction adheasive like liquid nails to glue a wooden board down, and then screw your amp into that.
dirtyblackhoe
02-08-2007, 10:00 AM
awesome man. My buddy is the owner of the ship so hopefully that's y he used such small screws and they didn't go thru. It looked like it barely even held to the carpet since they were so short...i guess i need to pull up the carpet and take a look...thanks mike
dirtyblackhoe
02-08-2007, 10:31 AM
BTW how much clearance is there from the metal to the gas tank?
MikeFbody
02-08-2007, 10:58 AM
I think it's about 1/4"..
dirtyblackhoe
02-08-2007, 11:10 AM
holy shit...i didn't realize it was that close...i just looked and u can see where he put the screw thru the metal (he didn't predrill it) but the screw was only 1/4" and I am not sure if the hole is all the way thru. I think I got lucky cause i couldn't smell any smoke and I don't think it went that far in it.
JR HAWK 9
02-08-2007, 11:25 AM
I just removed the child car seat anchor brackets and used the threaded holes along with longer bolts to bolt down my piece of wood. Although I -think- 2000 was the first year for those child seat anchors.....
MikeFbody
02-08-2007, 12:50 PM
yes, if you have a 2000+, the child seat anchors are ideal.
dirtyblackhoe
02-08-2007, 01:11 PM
Man I got a 99 so that's not in the picture. I think I am just going to get the subthump for the rear wall...cause I don't like the idea of it sitting on the back deck where everyone can see it...could i just screw it into the back wall or so i need to have a piece of wood there?
dragonrage
02-08-2007, 02:14 PM
What? Those triangle things? I've got 'em in a 99...
MikeFbody
02-08-2007, 02:52 PM
interesting, cause my 99 z28 did not..
wonder if it was a mid year change or something.
transambandit
02-08-2007, 04:03 PM
get some MDF board, place it under your carpet on the hump and bolt the amp to it, the weight of the board should keep the amp in place.
transambandit
02-08-2007, 04:04 PM
also subthump makes an amp rack for the back wall inside the trunk you could get
dirtyblackhoe
02-08-2007, 04:29 PM
I think I am going to do this for a temp thing
I think I am going to order this and do this in the next few weeks.
jrgswhitels1
02-09-2007, 09:39 AM
Yes,you can do it!! There is roughly a 1/2" spacing between the steel body and the glass-encased gas tank. I currently have a Bazooka subwoofer bolted down with full clearance, no leaks ,no issues. Just make sure you use the right length screws not exceeding 1".
