Sponsors?? Has someone test flowed the L76 intake??
had a nice discussion last night about its limits.... anyone have any feedback on its numbers?
if my heads flow 360ish.... but the intake only does 280... what good is it??
edit: found some info after the fact from someone who posted a link later in this post....
.500 319 225 71% 289
.550 332 227 68% 299
.600 340 231 68% 306
.650 340 235 69% 311
so 311cfm thru the stock L76 intake at .650 lift on stock heads...... not too shabby... the point is according to this fellas bench (which should have the flow of the heads closer to 330, you are only losing 30cfm from the intake)
Like Patrick said... get those heads to 360ish and you should get more flow thru that intake. especially down in the .300 - .550 flow range where stock heads do not even meet the fax flow of the intake....the more you raise the peak numbers of the heads the more you will see down in the lower lift areas.
Sorry. I meant to type L76. Here's the link:
https://ls1tech.com/forums/generation-iv-external-engine/602115-l76-intake-manifold-flow-results.html
Richard
Richard
LS1 Tech Administrator
Wow, I didn't realize the L76 intake knocked the head flow down by around 30 numbers at .500" lift and above. A good flowing cathedral port head with a stock FAST 90 bolted up flows as much.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by fast98
ya but its also way less in price
__________________
My point is, many people are ditching their cathedral ported heads/FAST 90 intake for the L92/L76 combo. The problem is, there haven't been any large gains.
My point is, many people are ditching their cathedral ported heads/FAST 90 intake for the L92/L76 combo. The problem is, there haven't been any large gains. So if you're starting from scratch, the L92/L76 is a cost-worthy option, but if you already have a good flowing set of cathedral port heads and a ported FAST 90, you may go faster by sticking with the "old stuff".
Marty
Originally Posted by Mr.MartyStone
I believe in another post Richard had, he flowed a ported 90/90 and AFR setup against a stock L92/L76 and it outflowed the 90/90 stuff by about 10 cfm at .500, and kept going up from there as the 90/90 setup stopped flowing around 288 cfm and went static.
Marty
Marty
Richard
Have you run the "carb" style intake that GM has? Is it even released?
I have been running some engine dyno testing with the L92 heads and they are very good for the money, but we are getting some high vac in the intake at high rpm. I am going to run a ported set today.
Kurt
Kurt
Originally Posted by Richard@WCCH
I thought I remembered posting that comparison. Read post #16 in the link I put up. I'll get some ported L92/L76 head/intake data posted up real soon. Patrick makes a very good point about upgrading to the L92's from aftermarket big breathing heads with FAST 90 intakes. The L92's really need some intake manifold manufacturers to get off their asses and build some suitable intakes for high power, high rpm engines. Waiting 5 or 6 years after the heads are out is a bit slow IMO.
Richard
Richard
Intake flow being the same does it do any good to increase head flow?
Originally Posted by Stang's Bane
I think we need to look at this as a more general question.
__________________
Absolutely! NASCAR engine builders found this out with restrictor plate motors. The better the flow and airspeed they got through the heads, the stronger the draw through the restricted intake manifold. We proved this for years when running ported heads with crappy LS1 (before LS6) intake manifolds.
Still.... at what point does the additional expense in head work become moot?
330cfm heads and a 300cfm intake?
360 intake heads and 300cfm intake?
400cfm heads and 300 cfm intake?
how much is it worth going from 330cfm heads to 365cfm??
L76 flow data link
Here is another link with flow numbers. The L76 intake will flow over 320cfm
if your heads flow 360cfm. www.notasponsor.com
Tony
Tony
Last edited by Patrick G; 02-09-2007 at 11:23 AM. Reason: Sorry, we do not allow non-sponsor links.
