Drag Racing Tech - Tires 4 launching w/trans brake
HAMRHEAD
02-08-2007, 08:17 PM
Just looking to see what the guys launching off the trans brake are using for tires. I'm more concerned with the sidewall of the tire. Are you using a stiffer sidewall or a softer one. The M6 guys benefit from a stiffer sidewall and auto's usually softer but not sure if launching off a trans brake?
Thanks.
tektrans
02-08-2007, 09:33 PM
I use the Goodyear slicks with the D3 compound. They are a stiff sidewall. They hook every time for me.
Slow00ls1T/a
02-08-2007, 09:34 PM
what is weight of vehicle
if it is one the heavy side I would go with a stiffer sidewall due to all the weight
HAMRHEAD
02-08-2007, 09:46 PM
Not sure of the weight yet as it is an entirely new setup but I expect it to be pleasantly plump!
tektrans
02-09-2007, 06:20 AM
Basically if you're over 3000lbs the stiffer sidewall is reccomended.
Slow Z28
02-09-2007, 08:43 AM
what's up man!
i ran the 28x10.5" stiff side walla M/T's and they were awesome.
I've run the Hoosier 28x11.5 QTP's in my 6speed and they'd hook a low 1.4 on the 6000 dumps.
it's more of a suspension thing than a tire thing though. get the tire height correct for what you want to trap and your gearing.
V6 Bird
02-09-2007, 09:51 AM
if it is one the heavy side I would go with a stiffer sidewall due to all the weightYou should run the stiff sidewall tire regardless since its a transbrake car. Aids in not wading up the tires and getting tire shake if/when the car is really leaving and making power.
HAMRHEAD
02-09-2007, 09:57 AM
I pretty much thought I would need a stiffer side wall leaving off the trans brake but needed to be sure first. I have 3.25 gears and am looking to use a 28" tire.
tektrans
02-09-2007, 11:11 AM
Do you have a power adder?
Gimp98TNT
02-09-2007, 05:28 PM
second vote for goodyears with the D3 compound, i run 28x11x15's they work awesome. cut a 1.37 60ft with the back tires on them. They also make a 10in version of them thats .5 in shorter.
HAMRHEAD
02-09-2007, 11:33 PM
yep!!!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
