93 Z28 Trans question
Old 02-08-2007, 10:09 PM
Cogs's Avatar
Default 93 Z28 Trans question
I might be getting a 93 Z28 as a trade, but it has a bad trans. Is this a 700R4 or a 4L60E? If a 4L60E, can I use any of them or are LS1 transmissions different?
Old 02-08-2007, 10:42 PM
LS1Tech Sponsor
performabuilt's Avatar
No a 700r4 is not a 4l60e its a 4l60 the non electronic version , Yours is also a unique yea in that it uses a different electrical plug than the other years But it is still a 700r4.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-09-2007, 12:32 AM
Cogs's Avatar
Then is 1993 the only year for the 4l60? Or what 700r4s can I swap in if it has a different plug?
Old 02-09-2007, 12:42 AM
daniel6718's Avatar
4l60 and 700r4 i believe are the same...both non electronic gm overdrives
Old 02-09-2007, 07:42 AM
LS1Tech Sponsor
That is correct they are the same 4l60 is just the proper name for the 700r4 , But 93 is the only year that uses that particular plug , We can supply the trans with that plug at no additional charge ,
__________________
Call 888-744-6542
Old 02-09-2007, 10:27 AM
Cogs's Avatar
Alright, I'm not really sure if I want to put up that much money for a trans for a completely stock car. Especially since I'm not sure if I want to keep it yet. Is there any way that I can swap the 93 plug from the 93 trans to say an older 700r4? And what exactly is this plug for?
Old 02-09-2007, 10:45 AM
LS1Tech Sponsor
the plug is for lockup an some feedback but yes it can be done , If you get and early one PM me and ill send you info about the swap
__________________
Call 888-744-6542
Old 02-09-2007, 11:09 AM
Cogs's Avatar
Thanks, I think I found a good trans already...but we'll see if I get the car or not.
