PCM Diagnostics & Tuning - Crankshaft position sensor
1hotls1
02-10-2007, 08:45 AM
When I replaced my failed sensor, the backfiring and other issues seemed to go away, but sometimes under extreme load the car will still miss or backfire a little. I have heard that there is a process for the computer to relearn the sensor. How is this done and is this likely to be my problem?
ChrisS@sdpc
02-10-2007, 09:34 AM
You will need a tool with bi-directional controls like HPTuners, EFILive, or a Tech-2. Generally speaking, anytime the PCM is replaced or the physical relationship between the crank and the sensor is altered this procedure needs to be performed. There are directions in the help manuals of EFILive and HPTuners.
Put the vehicle into park (auto) or neutral (manual).
Turn off all accessories and A/C.
Apply the parking brake.
Press the brake pedal. Keep the brake pedal depressed during the entire procedure.
Press Begin.
Gradually rev the vehicle to fuel cutoff (around 4000-5000 RPM's) over a period of about 4 seconds. When fuel cuts out, immediately release the throttle.
Allow the engine to come back to an idle.
Turn the ignition off for at least 15 seconds. This step is required for the VCM to store the newly learned configuration.
PunkNPonys
02-10-2007, 04:38 PM
Press Begin.
http://www.ls1tech.com/forums/showthread.php?t=656500
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
